Добрый день столкнулся с проблемой что в последней версии: 1.0936 не генерируются сертификаты Letsencrypt, certot переставлял не помогло
,Domain: *************.site
,Type: unauthorized
,Detail: Invalid response from http://**********.site/.well-known/acme-challenge/-SAlhN_41rrKhrDXoSsOv4gZjTUk8WOZzJwkVedrxHI [3*.13*.47.2*5]: 404
,Domain: www.**********.site
,Type: unauthorized
,Detail: Invalid response from http://www.***********.site/.well-known/acme-challenge/Ppy0J7-jhO964tvaap-DJD5dhgWg0idVYHiQSeuhcWw [3*.13*.47.2*5]: 404
,To fix these errors, please make sure that your domain name was entered correctly and the DNS A/AAAA record(s) for that domain contain(s) the right IP address.
,2022-04-09 14:26:10,236:DEBUG:certbot._internal.error_handler:Encountered exception:
, File "/usr/lib/python3.6/site-packages/certbot/_internal/auth_handler.py", line 91, in handle_authorizations
, self._poll_authorizations(authzrs, max_retries, best_effort)
, File "/usr/lib/python3.6/site-packages/certbot/_internal/auth_handler.py", line 180, in _poll_authorizations
, raise errors.AuthorizationError('Some challenges have failed.')
,certbot.errors.AuthorizationError: Some challenges have failed.
,2022-04-09 14:26:10,236:DEBUG:certbot._internal.error_handler:Calling registered functions
,2022-04-09 14:26:10,237:INFO:certbot._internal.auth_handler:Cleaning up challenges
,2022-04-09 14:26:10,237:DEBUG:certbot._internal.plugins.webroot:Removing /home/hosting/sites/hostingdn.site/.well-known/acme-challenge/-SAlhN_41rrKhrDXoSsOv4gZjTUk8WOZzJwkVedrxHI
,2022-04-09 14:26:10,238:DEBUG:certbot._internal.plugins.webroot:Removing /home/hosting/sites/hostingdn.site/.well-known/acme-challenge/Ppy0J7-jhO964tvaap-DJD5dhgWg0idVYHiQSeuhcWw
,2022-04-09 14:26:10,239:DEBUG:certbot._internal.plugins.webroot:All challenges cleaned up
,2022-04-09 14:26:10,239:DEBUG:certbot._internal.log:Exiting abnormally:
, File "/usr/bin/certbot", line 11, in <module>
, load_entry_point('certbot==1.11.0', 'console_scripts', 'certbot')()
, File "/usr/lib/python3.6/site-packages/certbot/main.py", line 15, in main
, File "/usr/lib/python3.6/site-packages/certbot/_internal/main.py", line 1421, in main
, File "/usr/lib/python3.6/site-packages/certbot/_internal/main.py", line 1294, in certonly
, File "/usr/lib/python3.6/site-packages/certbot/_internal/main.py", line 135, in _get_and_save_cert
, File "/usr/lib/python3.6/site-packages/certbot/_internal/client.py", line 441, in obtain_and_enroll_certificate
, cert, chain, key, _ = self.obtain_certificate(domains)
, File "/usr/lib/python3.6/site-packages/certbot/_internal/client.py", line 374, in obtain_certificate
, orderr = self._get_order_and_authorizations(csr.data, self.config.allow_subset_of_names)
, File "/usr/lib/python3.6/site-packages/certbot/_internal/client.py", line 421, in _get_order_and_authorizations
, authzr = self.auth_handler.handle_authorizations(orderr, best_effort)
,2022-04-09 14:26:10,241:ERROR:certbot._internal.log:Some challenges have failed.
в чем может быть проблемма????
полный лог прикрепил
Не генерируются сертифиаты для доменов
- Log.rar
- (6.75 КБ) 1142 скачивания
