Ошибка при переустановке Dovecot
Magicwd
Re: Ошибка при переустановке Dovecot
Сообщение Magicwd » Пн мар 24, 2025 3:30 pm
Продолжение:
Complete!
Last metadata expiration check: 0:00:58 ago on Mon Mar 24 17:22:57 2025.
Package clamav-db-0.103.8-1.brainy.el8.x86_64 is already installed.
Dependencies resolved.
Nothing to do.
Complete!
ClamAV update process started at Mon Mar 24 17:24:26 2025
DON'T PANIC! Read https://docs.clamav.net/manual/Installing.html
daily database available for update (local version: 15076, remote version: 27587)
Testing database: '/var/lib/clamav/tmp.257890b3dc/clamav-5820ce56e4b2b898b15f1358245e3091.tmp-daily.cvd' ...
Database test passed.
daily.cvd updated (version: 27587, sigs: 2074257, f-level: 90, builder: raynman)
main database available for update (local version: 54, remote version: 62)
Empty script main-56.cdiff, need to download entire database
Testing database: '/var/lib/clamav/tmp.257890b3dc/clamav-2af8396c23ca11957c4b5a5b3263a26c.tmp-main.cvd' ...
main.cvd updated (version: 62, sigs: 6647427, f-level: 90, builder: sigmgr)
bytecode.cld database is up-to-date (version: 335, sigs: 86, f-level: 90, builder: raynman)
Clamd successfully notified about the update.
[OK]
Adding user clamav to group exim
Adding user clamsmtp to group exim
Complete
[OK]
Complete
Run process...
Process completed.
[/code]
Сообщение alenka » Пн мар 24, 2025 3:31 pm
ls -al /etc/yum.repos.d/
rpm -qa | grep exim
Сообщение alenka » Пн мар 24, 2025 3:33 pm
Уберите clamav и spamassasin, у вас на это нет ресурсов.
Magicwd
Сообщение Magicwd » Пн мар 24, 2025 3:33 pm
rpm -qa | grep exim
# ls -al /etc/yum.repos.d/
total 88
drwxr-xr-x    2 root root  4096 Jan 15  2023 .
drwxr-xr-x. 133 root root 12288 Mar 24 17:25 ..
-rw-r--r--    1 root root  1190 Jan 14  2023 brainy.repo
-rw-r--r--    1 root root   776 Mar 24 15:44 CentOS-Linux-AppStream.repo
-rw-r--r--    1 root root   761 Mar 24 15:47 CentOS-Linux-BaseOS.repo
-rw-r--r--    1 root root  1130 Sep 15  2021 CentOS-Linux-ContinuousRelease.repo
-rw-r--r--    1 root root   318 Sep 15  2021 CentOS-Linux-Debuginfo.repo
-rw-r--r--    1 root root   732 Sep 15  2021 CentOS-Linux-Devel.repo
-rw-r--r--    1 root root   761 Mar 24 15:49 CentOS-Linux-Extras.repo
-rw-r--r--    1 root root   719 Sep 15  2021 CentOS-Linux-FastTrack.repo
-rw-r--r--    1 root root   740 Sep 15  2021 CentOS-Linux-HighAvailability.repo
-rw-r--r--    1 root root   693 Sep 15  2021 CentOS-Linux-Media.repo
-rw-r--r--    1 root root   706 Sep 15  2021 CentOS-Linux-Plus.repo
-rw-r--r--    1 root root   798 Feb  1  2022 CentOS-Linux-PowerTools.repo
-rw-r--r--    1 root root  1255 Feb  1  2022 CentOS-Linux-Sources.repo
-rw-r--r--    1 root root  1480 Jun  8  2021 epel-modular.repo
-rw-r--r--    1 root root  1562 Jun  8  2021 epel-playground.repo
-rw-r--r--    1 root root  1417 Jun  8  2021 epel.repo
-rw-r--r--    1 root root  1579 Jun  8  2021 epel-testing-modular.repo
-rw-r--r--    1 root root  1516 Jun  8  2021 epel-testing.repo
[root@magicwd ~]# rpm -qa | grep exim
[root@magicwd ~]#
Magicwd
Сообщение Magicwd » Пн мар 24, 2025 3:36 pm
clamav снес, а spamassasin не устанавливается и так).
Пробую exim установить
Сообщение alenka » Пн мар 24, 2025 3:37 pm
Капец, у вас подключены сторонние репозитарии (epel), возможно и пакеты из этих репо.
Пакеты brainycp, конфликтуют с пакетами epel. Удалите сам репозитарий epel, и пакеты которые установились по зависимостям.
После этого переустановите exim
Magicwd
Сообщение Magicwd » Пн мар 24, 2025 3:38 pm
Спасибо, сейчас сделаю
Magicwd
Сообщение Magicwd » Пн мар 24, 2025 4:00 pm
Пакеты не установлены, репозитарии удалил, exim все равно не устанавливается
Последний раз редактировалось Magicwd Пн мар 24, 2025 4:17 pm, всего редактировалось 1 раз.
Magicwd
Сообщение Magicwd » Пн мар 24, 2025 4:13 pm
Заметил такую ошибку
Magicwd
Сообщение Magicwd » Пн мар 24, 2025 4:27 pm
Попробовал переустановить связку и пропал apache, а сайты выдают ошибку 502 Bad Gateway
Перезапуск apache неуспешный. Сервис не работает.
