Не cработало автопродление Lets Encrypt сертификата
Добавлено: Пт фев 26, 2021 7:18 am
Вчера закончился сертификат на одном из доменов, но автопродление не сработало, в чем может быть причина?
Панель управления сервером
https://community.brainycp.ru/
File "/usr/lib/python2.7/site-packages/pkg_resources/__init__.py", line 3112, in
@_call_aside
File "/usr/lib/python2.7/site-packages/pkg_resources/__init__.py", line 3096, in _call_aside
f(*args, **kwargs)
File "/usr/lib/python2.7/site-packages/pkg_resources/__init__.py", line 3125, in _initialize_master_working_set
File "/usr/lib/python2.7/site-packages/pkg_resources/__init__.py", line 578, in _build_master
ws.require(__requires__)
File "/usr/lib/python2.7/site-packages/pkg_resources/__init__.py", line 895, in require
needed = self.resolve(parse_requirements(requirements))
File "/usr/lib/python2.7/site-packages/pkg_resources/__init__.py", line 781, in resolve
raise DistributionNotFound(req, requirers)
pkg_resources.DistributionNotFound: The 'pycparser' distribution was not found and is required by cffi
